TwinTurbo.NET: Nissan 300ZX forum - Pull all connectors and make sure none are corroded. Typical
Subject Pull all connectors and make sure none are corroded. Typical
Posted by Audioquest on July 01, 2008 at 9:54 PM
  This message has been viewed 152 times.
In Reply To only slight miss and still need help diagnosing posted by speedy z on June 30, 2008 at 09:01 PM
Message problem when you have intermittent idle and miss.
Could also be a faulty Coolant Temp Sensor, vacuum leak, or bad plug.
I use dental picks and small flat blade screwdriver to scrape away the corrosion, and then this cleaner followed by dielectric grease.
This stuff is magic
[ http://www.mgchemicals.com/products/801b.html ]
